DVB Viewer 4.0 Pro no Recordings !
lowspeed
Have checked my videos folder, temp/usr folders and DVBViewer folder !
I can see my hd is working but cant find the file, tested with PS/TS saving.
even timeshift file is on saving. 2 MB buffer all audio tracks on luck :wacko:
should be fixed on next release
delete it, its OK. must use the dvbv plugin recorder
Still problem with recording, either sound or video not both (PS/TS MPEG) this should be fixed in the next version !
Also the hide all menu's doesnt work in radio mode, cause then the tool menu is back (the status window is hidden tho)
try hide all menus in TV mode then switch to radio and its back. (it should be hidden)
