Balle Posted January 3, 2009 Posted January 3, 2009 I have a HTPC with 2 satelite cards installed (bda drivers). Running DVBViewer Pro (ver. 4) Both cards are connected to Sirius (5 degrees east) Do I have to scan both cards for channels or could they use the same channel list. How do I run one of the cards for viewing channels on my HTPC, and the other one for WEB streaming? Do I put "preferd device" on both? Do I need 2 instances og DVBViewer, if so how do I do this (copy the folder??) Quote
pastimer Posted January 5, 2009 Posted January 5, 2009 I have a HTPC with 2 satelite cards installed (bda drivers). Running DVBViewer Pro (ver. 4) Both cards are connected to Sirius (5 degrees east) Do I have to scan both cards for channels or could they use the same channel list. How do I run one of the cards for viewing channels on my HTPC, and the other one for WEB streaming? Do I put "preferd device" on both? Do I need 2 instances og DVBViewer, if so how do I do this (copy the folder??) assign the cards to the same group (A), now scanning one time this group will suffice. i see no way to specifically use one device for dvbserver and the other only local. But if you only watch or record one channel locally, ther will always be a device available to dvbserver, so not realy a problem i guess? there is no need to setup two instances of DVBViewer for you i think. it's not that easy too, because you have no control over the location of the DVBViewer data directory. Quote
