DVBViewer 4 problem with multiple pmt id programs
radek c (Poland)
hello,
I have problem with some programs from Polish Cyfra Plus package (all is legal stuff with working card with CI)
on transponder 12284 on Hotbird 13E for example, there are few channels with same pmt pid, and different service pid.
They are black. card is working ok, another programs that is having own pmt (different from others) working well, these are not.
another soft is working well with these programs.
Any idea ?
greetings from Poland
rc
oops.
here's my zip.
my graphic driver is latest stable nvidia driver - 180.48_geforce_winxp_32bit_english_whql.exe
my dvb card is TT budget S2-3200 stock version
motherboard EP GA45-UD3P - Intel EP45 chipset with ich10r bridge
dvd-rw & hdd - all sata devices, and nothing else in comp.
sorry.
rc
Technotrend, so it is a driver/support dll problem. see here for the explanation.
You could try an older TT support dll from here, maybe this helps. If it does work, it would be nice if you give a short feedback which version did it for you. :)
changing tt dll's didn't fix the problem.
logs from DVBViewer tell the sid is ok.
i think the problem is in communication with my card.
i'll try to change card.
Op, please remove this thread from "bug reports".
thank you
