Milly Posted January 3, 2009 Posted January 3, 2009 Is there an easier way to find feeds than going thru the pain of inserting transponder in transedit and scanning that way? The wife was after big bro live... got it eventually but it seemed a bit painstaking going thru transedit. Is there a way to just scan a tp on a frequency/polarisation etc... i don't seem able to figure it out! Quote
Lars_MQ Posted January 3, 2009 Posted January 3, 2009 use the scan window of the DVBViewer and select a fitting transponder list, select the freqency to scan and scan frequency. Quote
Milly Posted January 3, 2009 Author Posted January 3, 2009 use the scan window of the DVBViewer and select a fitting transponder list, select the freqency to scan and scan frequency. I tried that first, it didn't find it. At a guess i'd say the tp/frequency wasn't on the tp.ini Quote
