joaortnt Posted January 3, 2009 Posted January 3, 2009 what about if, wen we change a channel the DVBViewer indicates the rotation of the motor drive? exemple, wen we change the channel in hispasat to another channel at hotbird. appear something in the screen saing "motor moving to.." or something like that. Because in my personal case, sometimes the motor doesn't move at all, and with that i'll know wen it moves Quote
Derrick Posted January 3, 2009 Posted January 3, 2009 There is no way to indicate whether the motor is really moving. The counting by the sensor is managed by the motor itself and not in the application. Only if the driver would return the increased current drawn from the lnb-supply an indicator would be possible. Quote
patrona Posted October 1, 2009 Posted October 1, 2009 Pls add an OSD progress bar - indicator during motor moving. It is not necessary to show real progress, the indicator can be shown during estimated time, calculated from H/V motor power (speed of rotation) and angles (between current and new position). Calculated progress bar will be much better then current black screen; it will remember to user, that new selected channel is on another satellite and has to wait for a moment... Quote
