Favourites
Luuk
I haven't changed anything on my computer for months yet tonight when I started DVB (as I do every day) the favourites were gone. When I try to add them again they show up in the channel editor but not under Channel on the main screen. I also do not seem to be able to save favourites or call them up again from disc. What could be wrong?
Luuk
I should add that I am using DVBViewer Pro V3.9.4.0 running under Vista Professional.
Try renaming favourites.xml in your configuration folder (go to About\Configuration folder pull-down menu). And then rename favourites.bak to favourites.xml. If that doesn't work try deleting favourites.xml altogether - it may be corrupted and it will be recreated.
Also upgrade to 4.0 for many updates.
-Mack
Edited by HenPen
