DvbServer Connection Problems
Springveldt
Hi
This problem relates to a post I made in the general section last month...
http://www.DVBViewer.info/forum/index.php?showtopic=30897
I've installed v4 now and everything works really well apart from connecting to DvbServer locally. I've attached my support.zip.
From looking over the debug file I think the problem is caused in Streamthread with an Error 10057.
06.01.09 20:34:28 TDVBDevice.InitDevice SkyStar 2 TV PCI
06.01.09 20:34:28 TDVBDevice.InitDevice Unicast Network Device
06.01.09 20:34:28 TDVBDevice.InitDevice Multicast Network Device
06.01.09 20:34:29 LoadWindowDefs Loading WindowDefFile: C:\ProgramData\CMUV\DVBViewer\windowdef.xml
06.01.09 20:34:36 Settuner Start
06.01.09 20:34:36 Streamthread created
06.01.09 20:34:36 TUCStreamThread Sessionstarted
06.01.09 20:34:36 TCMDSocketThread Sessionstarted
06.01.09 20:34:36 Streamthread SessionConnected
06.01.09 20:34:36 Streamthread SessionClosed
06.01.09 20:34:36 Gotstr OK.
06.01.09 20:34:36 Allocate Unicast Network Device
06.01.09 20:34:36 Settuner Found usable hardware
06.01.09 20:34:36 TDVBHardware.SetTuner PMT: 260 - SID: 10355
06.01.09 20:34:36 Sendstr SETTUNER 1 10817 22000 9750 0 1 0 4 2328 2327 260 10355 1 0 0 24 0
06.01.09 20:34:37 Gotstr OK.
06.01.09 20:34:37 Streamthread SessionConnected
06.01.09 20:34:37 Streamthread SessionClosed
06.01.09 20:34:37 Streamthread Error!: 10057
06.01.09 20:34:37 Settuner End
06.01.09 20:34:37 Sendstr ADDPID 2327 2328 0 260 2329
06.01.09 20:34:37 AddAVCodecs VCodec: CyberLink Video/SP Decoder (PDVD7), ACodec: CyberLink Audio Decoder
06.01.09 20:34:37 VCodec CyberLink Video/SP Decoder (PDVD7)
06.01.09 20:34:38 ACodec CyberLink Audio Decoder
06.01.09 20:34:38 AddVideoRenderer Add Overlay
06.01.09 20:34:39 Used Filter 0: Video Renderer
06.01.09 20:34:39 Used Filter 1: Default DirectSound Device
06.01.09 20:34:39 Used Filter 2: AC3Filter
06.01.09 20:34:39 Used Filter 3: Overlay Mixer
06.01.09 20:34:39 Used Filter 4: CyberLink Audio Decoder
06.01.09 20:34:39 Used Filter 5: CyberLink Video/SP Decoder (PDVD7)
06.01.09 20:34:39 Used Filter 6: DVB Source
06.01.09 20:36:22 Streamthread SessionConnected
06.01.09 20:36:22 Sendstr UNSETTUNER 1 10817 22000 9750 0 1 0 4 2328 2327 260 10355 1 0 0 24 0
Thanks
10057 = Socket not connected. Does your firewall interfere maybe?
Thanks for the reply Lars.
The Viewer and Server are running on the same box so I wouldn't have thought the firewall was the problem. I disabled the firewall and still nothing.
I then decided to play around with the unicast settings and found the problem.
If I assigned the Unicast Device Interface to the IP of my SkyStar2 card, it won't stream properly.
To get it working, I changed this address to the default all interfaces one.
I take it I had it set up wrong in the first image? Should the DVB Unicast Device be the IP of the SkyStar2 card or just the server it is running on?
Thanks
Edited by Springveldt
The second one you wrote...
