Downloading 3.9.2
Benjamin D
Hello, this is a message for the DVBViewer team :
I purchased and installed DVBViewer Pro 3.9.2 some time ago. I realized yesterday that I did not make a copy of the setup.exe file, so I will not be able to reinstall it if my HDD has an issue.
Is it possible to have that version back on the customers download area ? I only saw 3.9.4, which has given me new bugs when I installed it.
Thanks in advance.
Hello,
no chance. Only the versions in the Members-Area are available!
take a look in the installation folder of your 3.9.2 installation, there ist a folder setup. there you'll get the setup.exe
if you try the 4.0, you have the "bugs" again?
but there was a beta test for several months! why not take a beta and help to eliminate the "bug".
:angry:
Hi hdv,
Thanks for the tip, I got the setup file back and will sleep better now :angry:
Regarding helping out with the beta version, yes you're right... unfortunately my wife and kids and me use the HTPC for family TV, so I can test the beta only at night when everybody is asleep... not very practical... the "bug" I saw in 3.9.4 was in my opinion a minor one. I'll give 4.0 a try, the changelog is impressive.
Thx
