DVB card list is empty.
fabounnet
Hi all, i tested my hardware on vista x64 before testing on windows server 2008 x64.
On vista, i got no problem using DVBViewer. I then switch the hardware (Pinnacle Dual DVB-T Diversity 2000e usb stick) to the WS2008 machine.
Use the same drivers but in WS2008, the dvb card list is empty in DVBViewer.
Is there something i missed ?
i think the Windows server does not support BDA.
Thanks, i will find a wat and tell you.
