Create a timer from outside DVBViewer / DVBService
groovyclam
Is it possible to create a timer for a recording from *outside* the DVBViewer application ( e.g. command line or some other interface ) that DVBViewer will then pick up and action.
I have tried writing to the "timers.xml" file directly but DVBViewer does not recognise this if DVBViewer is running at the same time as the edit it made.
Preferably I would prefer this to work with the DVBRecording service beta instead of the main DVBViewer Pro app.
I don't want anything to appear on screen when "poking" timers into DVBViewer.
I'd just like some way of passing "channel", "start time/date" "end time/date" and "outputfilename" to the DVBService ( or DVBViewer ) and it adds the timer to its list of timers.
Edited by groovyclam
Found the answer to my own problem:
The plugin "TV Genial + CMDline 1.1" in the members area does just this.
Download it - unpack, put the dvbv_tvg.exe in your DVBViewer install directory.
Check out the install.txt - it's in German but not too hard to decifer.
Run as a command, for example:
dvbv_tvg.exe -d "my own description" -c "CHANNELPID" -e 12.01.2009 -s 17:00 -p 17:30 -a 0 -t 0 -v 0 ( this sets a recording for 12th Jan 2009 starts 5pm ends 5:30pm )
( get CHANNELPID from your favourites.xml in your DVBViewer directory e.g. for UK DVB-T BBCOne it should read -c "1650004040|BBC ONE" )
It also works fine with the DVBService ( hurrah! )
In fact it searches in the following order and takes the first found option:
1. look for a running dvb service -> send direct
2. look for a running DVBViewer Pro -> send direct via COM
3. look if started in a DVBViewer Pro program folder -> save into the timers.xml
4. look if started in a DVBViewer GE program folder -> save into the setup.ini and look if GE is running -> inform to reload.
I just have to find the time to translate the readme to english. :bye:
Thanks for writing it Lars - it works brilliantly
  • 6 months later...
I cant get it to work. Is it because i use DVBViewer (4.2.1.0) as a client to Recording Service (1.5.0.21)
My commandline looks like this:
dvbv_tvg.exe -d "Test" -c "1115685465|DR1" -e 28.7.2009 -s 1245 -p 1300 -a 0 -t 0 -v 0
But nothing i scheduled in DVBViewer or Recording service. I have also tried to use the Recording Service switches eg.: -xp, -xa, -xd, -xt, -xx, -xu and -xsvc. But nothing is scheduled in the recording service
  • 2 months later...
Hello.
Currently, I use Windows XP Pro. SP3's scheduler to launch DVBViewer Pro v4 about 5-10 minutes before its timer takes over to record with one or both dual HDTV tuner cards. I don't use any services. Can this tool be used for this setup? Too bad we can't just edit a timer.xml and let DVBViewer reread via telnet/SSH. Command line parameters are confusing and complex!
Thank you in advance. :bye:
