no osd in radio and satelite problem
spikemaster
i am using DVBViewer pro 4.0 pro
i am using no extra plug-in third party.
i installed your netstream plugin only and it is not enabled.
i have two problems with that configuration:
audio plugin-- intervideo
video plugin-- cyberlink 8
1. osd does not work when listening radio.
2. i am using hotbird and turksat. When watching a channel on turksat then switch to a channel on hotbird there is no problem, but when i want to come back to turksat from hotbird, LNB signal cutoff and the only solution is to restart DVBViewer. when i do that the last channel that switched (turksat) comes to screen with no problem.
-I tried to uninstall dvbviewr and making a clean DVBViewer installation.
-I tried other vide and audio codecs
-I tried unchecking it was samething like "disable LNB on a problem" from options.
This tries give me no solution, what's your suggestion?
