DVBServer Stream Encoding
Stun
Hi all.
I am using DVBServer in Unicast mode with one client. I need somehow to compress traffic from server, because I connect to server through Internet (not local network). Is it possible with some plugins or anything like that?
If you stream to a DVBViewer Client it is not possible to re-encode the stream.
To recode (and... "compress") the stream to use it over Internet, you can use the DVB Recording Services; but you have to use VLC as client and change channels from a huuuge drop-down list of his web interface (still beta - no favourites ATM :( ) but it's really worth a try...
You can find it in the Member Area, Beta section; more info in the specific tread
:bye:
Edited by Gioxy
