Lars_MQ Posted January 17, 2009 Posted January 17, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.0 Betaexpires 14.2.2009 ---------------------- New: Complete rewriten DiSEqC 1.1 / 1.2 support (only for DVB-S devices allowing to send DiSEqC raw commands), which means, support for motorized dishes and cascaded DiSEqC elements (uncommitted switches, positioner behind a switch). All thanks to griga. New: DiSEqC Editor ("DiSEqC expert mode"). Allows to assign user-defined DiSEqC command sequences to a satellite position - as you will see - much more conveniently than with the DiSEqC Editor of DVBViewer Pro 4.0.0.0 and earlier versions. Removed: Positioner Console, please use transedit 3.27+ for this. it is much better suited. Fix: The COM Interface gave a wrong value for the stereo audiomode. Add: EPG-Parser: Added slv as language identifier. Change: Removed check for driver supports color changes. Fix: Grigas fix for problematic AC3 streams detection. Add: Support for Pinnacle PCTV 380e/510e DVB-C hybrid. Change: Brightness default is now set according to the used renderer. Should cure the Overlay too dark problems. Please reset the brightness value to default. Fix: Problems with 120 dpi in some options windows. Fix: OSD Media windows: Not existing network shares (UNC paths) do not cause any blocking anymore on first opening of the window. For this the support for the folder.jpg files has been removed for all UNC Path shares in the root view. Fix: Media playback with a not in the DVBViewer predefined aspectratio cause a no update of the framerate in the #Datatags. Change: Adding new virtual DVB device can be done in the hardware options window via the "+" button. The data now is saved to the network.xml instead of the usermode.ini. Existing data will be taken into account. Update: Updated language files. For details please read the DiSEqC instructions (most of it applies also to the DVBViewer Pro): English German Also take a look at the transedit announcement: English DVBServer: ---------- Change: Adding new virtual DVB device can be done in the hardware options windows via the "+" button. The data now is saved to the network.xml instead of the usermode.ini. Existing data will be taken into account. Add: Support for the new DiseqC handling. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted January 18, 2009 Author Posted January 18, 2009 Hotfix 4.0.1.1 Beta is in the Membersarea. HotFix: the diseqC position data was not handled correctly. Sorry about that.
Lars_MQ Posted February 12, 2009 Author Posted February 12, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.10 BETA expires 12.03.2009 Add: Tweaks: MinVolume in case you can hear something even if muted, lower this value. Fix: Timers: minimal free disc space was not taken correctly into account if bigger than 2 GB. Add: Hardware: Support for Turbosight clones. Add: Hardware: Support for TerraTex XE MK II clones. Fix: EVR: A Black box stays on the screen fixed. Fix: TT diseqC fix from Griga. Add: Support for Closed Captions of dish network. Fix: Premiere EPG: The EPG could fill up the whole memory if the channel premiere direct was tuned for a long time. Add: Options: Service Options dialog. IMPORTANT: This page is still under heavy development! Add: Support for several Recording Service functions / communication. Download EPG from service. You can tell the viewer how many days of EPG you want to download. Notice: this doesn't create magically 14 days of EPG. You only get as much data as the service has gathered. Send EPG programmed timers to service: If you select this option all timers you program via EPG in the EPG Window or OSD are send directly to the service. There is ATM no feedback and you can't edit or see the timers in the DVBViewer directly. You can also create manual timers in the recorder window which are send to the service. Connect to recordings list. This one is quite tricky and you need knowledge about the management of network shares and user rights under windows to make this work. And you have to setup this function in the Service according to it's readme_svc. Don't use this function with a local DVBViewer only with remote clients! Background: A real streaming of recordings from the service would clash with the playback functions of the viewer. A major rewrite would be needed, which is too much ATM. So for now I choose the easy way and use network shares to realize the streaming in a local network. For this the recordings database of the service needs to be setup in a way that it uses UNC paths to the recording folders instead of local paths. For this and for the client access the access rights have to be configured correctly, which can be a little complicated and done wrong could result in no recordings can be done by the service. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted February 14, 2009 Author Posted February 14, 2009 Hotfix 4.0.1.11 is in the Membersarea. Fixes issues with detecting seperate NovaSPlus compatible Cards wrongly as hybrid cards.
Lars_MQ Posted February 22, 2009 Author Posted February 22, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.20 BETA expires 22.03.2009 Fix: DVB-Subtitles: fixed wrongly shown pixels. Fix: Recordings in MPEG Format with APID =0 and VPID = 0 are now changed to the TS format and the PIDs are dynamically added from the PMT. Add: Recordings list from the service: recordings now can be deleted. Remember this does also delete the real file not only the database entry (same behavior like in the web interface). Fix: Tune only timers (EPG Window → prebook) are not send to the service anymore. Add: If the DVBViewer is running after Standby or Hibernate, it refreshes it's EPG from the service. Add: Service timer lists can be shown and edited. You can enable this in options → service options. Only Recording timers are listed because the DVBViewer doesn't know the other timer types. Not every function of the DVBViewer recorder window is supported. Recording folders, no file write and Transponder dump from the edit window do not work. Unknown timer actions or end actions are mapped not accepted and mapped to the default value of the service. Notice: Instant timers are handled by the DVBViewer not by the Recording service. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted March 1, 2009 Author Posted March 1, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.25 BETA expires 28.03.2009 Fix: - Hybrid tuner handling: Fixed some issues. Fix: Recorder window: fixed a typo introduced in the last version, which caused the window being placed at the top of the screen. Add: Extended the controlling of the Recording service (V. 1.4.7.65+). New menu in the OSD: OSD main menu → system → Rec service - with the following options: Standby, Hibernate, Shutdown (PC): Triggers the according action in the recording service. The service does give a 30 seconds warning. In this time window all the DVBViewer clients show a dialog window, where the user can stop the action. Load EPG: gets the EPG from the service. Wake On LAN: Wakes the recording service PC (even from Soft-Off). The PC must be configured to accept WOL. Important: The DVBViewer needs to have at least once contact with the service PC to get it's MAC address. These functions are also accessible via actions (see actions.ini). Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted March 12, 2009 Author Posted March 12, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.30 BETA expires 15.04.2009 Fix: Service options: If password is empty the user name field is also set to empty. Add: Service options: Added "test connection" button (needs 1.4.7.70+ of the service). Add: Service options: Added a error message if the Service can't be contacted. Fix: Stopping recordings via the OSD-Blue pop up menu doesn't show the recording menu anymore. Add: Extended error logging for virtual DVB devices. Fix: A rounding error caused wrong satellite position calculation on input in the channel editor window. Add: Christian added a Shockwave/Flash renderer (experimental) you need flash installed. Fix: EPG Window / OSD: Cyrillic and several other char sets are now also displayed correctly. Change: DVBViewer now shows “Automatic” in the network device configuration instead of “0.0.0.0”. Add: Missing translations. Add: DVBServer: Twinhan WDM support back again. Change: DVBServer now shows “Automatic” instead of “0.0.0.0”. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted March 20, 2009 Author Posted March 20, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.35 BETA expires 21.04.2009 Fix: Windows 2000: DVBViewer wouldn't start anymore. Fix: ASF Playback and Vista. Add: DiseqC for BDA DVBWorld device Fix: Problems with using the recording service and no network card installed fixed. Add: ShareLNB can only be activated if more than one enabled DVB-S device is present. Add: "Autodetect Audio/Video" will be automatically disabled if a network device is in use. Fix: For playback issues with Kathrain trp recordings. DVBServer: Add: DiseqC for BDA DVBWorld device. Add: ShareLNB can only be activated if more than one enabled DVB-S device is present. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted March 28, 2009 Author Posted March 28, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.40 BETA expires 28.04.2009 Change: Reworked teletext options page. Fix: EVR crash on building the graph with some graphic cards, introduced last beta. Fix: Terratec XE MKII DVB-T devices do not need the low bandwidth option anymore if connected to a USB 2.0 port. Will be configured automatically. Fix: On single core systems the recording service timers were not shown after starting. Add: Mouse options: added "do nothing" and "zoom" to the mouse wheel functions. Fix: Griga reworked the mpeg recording to make it more robust. Change: On Standby/Hibernate in Vista the DVBViewer now closes down the playback. On waking up the last channel is tuned (if activated in the TV+Radio options). Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted April 11, 2009 Author Posted April 11, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.50 BETA expires 10.05.2009 Change: Move user specific settings for the service from the setup.xml to userdata.xml. Fix: If the DVBViewer did crash while the service is running, it couldn't be started anymore (also applies for the DVBServer). Fix: The MAC detection for WOL did not work correctly if the server name was used instead of the IP. Fix: Griga fixed a bug in the RDS parser. Add: Seamless playback of (unencrypted) Blueray disks. Reworked: Main movie detection of Blueray disks. Add: HDDVD support improved. Add: In the Service options you can activate the new option: "Tuning Priority". If activated the Viewer can force a channel change, even if he is not the first connected client. Of course this does not work, if a recording is running on the device in question. Needs Recording service 1.4.7.95+. Add: If the DVBViewer connects to a recording service and the channel can not be tuned because all devices are in use and none is fitting, It gets redirected to a working channel. Needs Recording service 1.4.7.95+. Fix: Potential problem with the format detection corrected, several optimization (by griga). Add: Some more settings for process priority. Add: Network CAM/MMI. Needs Recording service 1.4.7.95+. Updated: Language files and translation changes. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted April 19, 2009 Author Posted April 19, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.55 BETA expires 12.05.2009 Fix: OSD Teletext: Missing text on SF2. Fix: VODSource: Shoutcast should work again. Add: If the recording service forces a channel change a message is shown now. Fix: OSD, VMR/EVR and encrypted channels. As long as a channel can't be decrypted the "overlay" OSD is show in case there needs to be a message displayed. Update: Several internal optimization for the playback detection by griga. Fix: Several small cosmetic changes in the DVBServer interface. Fix: EVR/aspect ratio change and PIP. Hopefully a solution for missing picture after a aspect ratio change and EVR. Add: Service options: Replaced the tuning priority check box with a value (0-100) to allow a better control between clients (needs Recording service 1.4.7.105+). Fix: VMR 7 didn't work with YUV anymore. Please post all reports to the english or deutsch beta forum.
Lars_MQ Posted April 27, 2009 Author Posted April 27, 2009 In the Betasection of the Membersarea is a new beta of the DVBViewer Pro. This is a beta! So don't use it as a production system. Installation: You need a working DVBViewer Pro 4.0.0.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. Please post all reports to the english or deutsch beta forum. The beta is meant for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure. In case of FAILURE the report MUST include - the exact steps to reproduce the problem. - the support.zip and other relevant data. See also on top of the BETA threads in the DVBViewer Forum for further instructions. Version 4.0.1.60 BETA expires 20.05.2009 Fix: DVBSubtitle: HD DVBSubtitle as used by BBC HD do now work. Change: DVBSubtitles: optimized memory usage of DVBSubtitles. Change: VODSource. Several improvements and extensions. Now you can play mp3 and aac streams via the VODSource. If possible all usable metadate is extracted from the streams. Change: Playback of streams: Several improvements on playback of streams. Detection of embedded Shoutcast or ASX playlists in asx playlists (asx V.1 and V.3). Detailed media description of the streams (if possible) (resolution, bitrate etc.). Works also with the ASF Reader. ASF Reader: If possible all usable metadata from the stream is read. Depends on the stream provider if there are any. [*] Reworked: Daemon tools support reworked. Now the completion of the unmount command is detected and then the mount command is send. [*]Reworked: Daemon tools (iso) options: Changes in the options needed a reload of the DVBViewer. [*]Reworked: DVD Handling renovated. The selection between multiple DVD drives now works. Support for Blueray and HDDVD images and folders rips in the OSD. [*]Removed: DVD Playback and Fileplayback without DVBSource now don't support customs graph files anymore. [*]Added: Experimental UniCable support according to the EN50494 standard. (What is UniCable? English Deutsch). Please note: UniCable will only work with TechnoTrend and FireDTV DVB-S/S2 devices. Other device drivers don't provide the means for UniCable support yet. In case of a TechnoTrend device the file ttBdaDrvApi_Dll.dll (optionally installed with DVBViewer Pro) must be present in the program directory. UniCable support is activated by inserting two lines in the appropriate device section of the file hardware.xml, while the DVBViewer is closed. The UniCable entries must look like this: <entry name="Slot">N</entry> <entry name="SlotFrequency">FFFF</entry> where N is the slot number (0..7) and FFFF the slot frequency (intermediate frequency, IF) in MHz on which different transponders are routed to the receiver. Example: <entry name="Slot">6</entry> <entry name="SlotFrequency">1980</entry> You may find these values on the antenna socket. Please note: On sockets or in manuals the slots may be numbered from 1 to 8. You will have to subtract 1 in this case. If you want to take part in the UniCable discussion, please join in here. It's a German thread, but you may also post in English. [*]Change: BDA-Devices: The search for the BDA_RECEIVER_COMPONENT fitting for the device to open reworked. In most cases it works without the SkipComponent hack (it is still there but if possible ignored). This should fix the Problems with two or more Twinhan/Technisat/Terratec S2 devices. [*]Change: Favourites: From now on there are no duplicate entries of channels with the same ChannelID in the favourites list allowed. They collided with the fav+/- function. Existing duplicates will be removed. [*]Add: Graph rebuild, manual Video/Audio A/B change take now the timeshift wirning into account. [*]Add: DVB-S2 Detection of Twinhan/Technisat devices improved. [*]Several small improvements and optimizations. Please post all reports to the english or deutsch beta forum.
