Mattile71 Posted January 18, 2009 Posted January 18, 2009 I have Anysee Cable C30 digital receiver(with conax) Our building has channels at 154 ,162, 170, 178 Mhz. Anysee program works fine but it has problems with font scaling.Therefore i would like to use DVBViewer instead. Parameters are 4000 Ksymbols/sec, Q64 (ie 6 bits/symbol) Problem is that I cannot get DVBViewer to search those channels.Whatever i try, the search goes from 149500 Khz to 156000 Khz. It does not stop at 154 Khz at all ! If I try to put in 154 Khz manually by typing it, DVBViewer scans the channel 50 Mhz. So a totally wrong one. Is there any way to make this work ? (viele danke fur ein Antwort) Quote
