Videorecorder timer and channelnumbers
boborg
When you have recordings set up in the timer these use channelnumbers. But if you have moved channels in your channellist these numbers may now be wrong in the timer settings.
Not a big problem but would be nice if changes made in the channellist could be read by the timer and update the Channelnumber. One might forget to do it manually.
The DVBViewer first tries to find the channel 'by name'. If this doesn't succeed, it is chosen 'by number'.
Griga
