Strange behavior with mkv
newlynx
I 'm now using DVBViewer 4.0 and I 'm in most things satisfied. The only problem I have is that some mvk videos play and some not. I am using PowerDVD8 (h264) and Haali media splitter. When they don't play I can see from the filters section that the video has loaded but the screen is black.
Is someone else having problems with mvk videos?
  • 1 month later...
I have solved the problem. Converted the external srt from ANSI to Unicode and now mvk videos play well.
But when the mvk contains internally subtitles the outside subtitles are not in the list menu. Is there any solution to this?
  • 1 month later...
Yes, there is. PM if you are interested
  • 2 months later...
Has anyone solved the above problem? I'm trying for a long time now without success.
Use mkvmerge to dissable unwanted internal subtitles and add external subtitles and set it as default track.
Yes, I know that solution but because you can have both internal an external subtitles when using MPC or Zoom player, I was wondering how to do this in DVBViewer...
