DVBVIEWER Supported CAMs
newen
Is there a list of supported CAMs in DVBViewer? If there is not can we make one with help of forum users? Usefull info would be:
CAM type: Oasis2 fw:xxyy
Card provider: TotalTV
DVB-S/S2 Hardware/Driver version: Tecnisat Skystar HD2 v1.1.1.302
CI module: Technisat CI for SSHD2
DVBViever version: 4.0.0
OS: Vista x64 SP1
Status: Not tested yet
The question is formulated wrong.
The viewer does know nothing about CAM it only knows about special functioncalls of some dvb-hardware drivers which interface with the CI on this hardware.
CAM handling itself is done entirely by the dvb-hardware/driver. If it can't handle a CAM type, the DVBViewer can't do anything.
So you have to ask:
- has the DVBViewer CI support for this dvbhardware/driver combination.
- Can the dvbhardware/driver version handle the CAM "xyz" with firmware "abc".
- Can the CAM/firmware version handle the encryption of the wanted payTV channels.
You see it is not as easy as you may think :)
Haha, is it ever?
I agree that technical value of my questionere is kind of low but I'm counting on "real life" expirience of DVBV forum users. IMO it will provide good info for those starting from scratch and give them a chance to buy a hardware tested with specific paytv provider.
ok, could be useful :
CAM manufacter: SCM
Type : VIACCESS 1.0 V484
Application : V1.08
Provider: SRG SSR
DVB-S/S2 Hardware/Driver version: Technisat Skystar HD2
OS: XP SP2
Status: Good
CAM manufacter: Smit
Sw version : 1.6.1
Hw version : 1.3.0
ACS Sw Version : 463-2.1.2.11-BROAD
Provider: SRG SSR
OS: XP SP2
Status: Some glitches (don't know why)
