Large Pro7 Bitrate Differences
Technofriend
Schweiz/Austria: 650
Germany: 450
I know that this is not new, but is there a reason for that?
Do they need the spare bits for AC3, or do they use a better compression (eg. very variable bitrate) ?
As the bitrate seems to fluctuate much more on the german channel.
EDIT:
I just made a bit more research:
It's the same with all channels that I tried: Sat1, Pro7, RTL2, Kabel1.
As a rule of thumb I found that it is always a good idea to choose the austrian version of a channel by default if quality is the issue.
Or the german channel if harddisk-space is the issue...
Yes AC3 needs a bit from the whole bitrate.
Bitrate = A+V <-- Schweiz and Austira
Bitrate = A+V+AC3 <-- Germany
IMHO is the Bitrate the same. On the recorder window you see only for the recordet PINs (V+A or V+AC3) Thats the reason why schweiz and Austria have a better picture.
Steffen
