Del Boy Posted January 25, 2009 Posted January 25, 2009 First of all I have looked through the forums and although there are very similar problems I haven't found anything particularly relevant to me! DVBViewer 4.0 keeps crashing after about 10-15 mins or so.. sometimes I get a little message from Vista to say that DVBViewer has stopped working... This is really annoying me as it is rendering recording or any sort of comfortable viewing impossible.. Please Help! Im using a FloppyDVB with the latest drivers and an Nvidia 6800GS... My motherboard is an Asrock SKT-939 939N68PV-GLAN using the NVIDIA nForce 630A MCP chipset. Thankyou!! support.zip Quote
Del Boy Posted January 25, 2009 Author Posted January 25, 2009 I've found this file with what I believe could be is the problem.... DVBViewer.txt.. this is the line of text that is in it... 25/01/2009 10:13:35 EAccessViolation raised by instanceNon Class Object of class TExPopupList at 006B9F2A:Zugriffsverletzung bei Adresse 006B9F2A in Modul 'DVBViewer.exe'. Schreiben von Adresse 00000098 Quote
alexs3d2 Posted February 5, 2009 Posted February 5, 2009 Still no solution?? I am having the same problem on my system and I have searched and searched through the forums, only discovering that there are several others facing the same issues. My configuration: -Terratec Cinergy S2 HD -Intel Q9450 -4GB RAM -ATI RADEON HD 4850 Catalyst 9.10 -Asus P5Q (P45 EXPRESS) -Windows Vista Ultimate x64 As one sees, the configurations are vastly different, which leads to believe there must be a serious fault in the program! Quote
