OSD Pixelated in everything but overlay
remlap
The OSD is pixelated in everything but overlay.
When in overlay everything is all washed out.
How can I fix this?
Cheers
Edited by remlap
How can I fix this?
Cheers
Did you get this problem as soon as you installed DVBViewer or have you changed something like BIOS, driver or switched from older verion to DVBViewer 4.0? Can you give details on what CPU and graphics chipset you are using?
Its since 4.0 came out so its not my graphics card or CPU.
OK, can you post a screenshot- did you uninstall every version of DVBViewer before installing? Are you running XP or Vista?
Here is what it looks like in EVR Vista
Edited by remlap
No insight guys?
I am not sure what you mean by pixelated- which skin is that?
Fixed it turns out I had weirdly set Vista to turn of Aero every time I loaded DVBViewer.
Argh indeed o:)
Edited by remlap
