BSOD when resizing window
wai0808
Hi my PC becomes BSOD when I tried to resize the window side with the mouse(click on the border and try to move)
I tried DVBViewer's safe mode, but the PC still BSOD
Here is the Hardware config
Mygica X8506 PCI-E TV Card
A64 x2 4200+
nforce 4
ATI X700 PCI-E
1.5GB ddr
Software config:
WinXP SP3 Eng
DVBViewer 4.0, 4.0.1.1
ffdshow-rev2527_20081219_clsid_sse_icl10 or ffdshow-rev2608_20090110_clsid_sse_icl10 (using libmpeg2, dscaler bundle and liba52)
ATI 8.12 driver
any idea to solve this problem? or to trace the root of the problem?
thanks!
Under XP/Vista BSODs are caused by drivers resp. conflicts between drivers, not by applications. That's where you have to search... reboot and start DVBViewer without playback (by using the commandline parameter -c). Does resizing the window still cause a BSOD? If not, play a file with DVBViewer, so the DVB device is not in use. Try again... if it only happens when DVBViewer is busy with TV/Radio, I'd assume a conflict between the graphics card driver and the DVB device driver. Putting the DVB card into another slot may help in this case.
no BSOD in this case
i used 3.9.4 before, no BSOD when resizing. But after ugraded to 4.0, BSOD happens..
