antdude Posted January 27, 2009 Posted January 27, 2009 Hello. Is there a way to tell DVBViewer Pro v4 which cards to use on specific TV channels? Thank you in advance. Quote
Tjod Posted January 27, 2009 Posted January 27, 2009 You can use the Channel groups for this. Select in Options > Hardware which card should be used for which group. And than change the group from the Channels in the Channel list editor. Quote
antdude Posted January 27, 2009 Author Posted January 27, 2009 You can use the Channel groups for this.Select in Options > Hardware which card should be used for which group. And than change the group from the Channels in the Channel list editor. Thank you. That feature is awesome. Quote
