DVBViewer 4 not stable on Windows XP x64
LamSoft
Event Type: Information
Event Source: DrWatson
Event Category: None
Event ID: 4097
Date: 2009-01-27
Time: 04:04:59 PM
User: N/A
Computer: LAMSOFT-SERVER
Description:
The application, C:\Program Files (x86)\DVBViewer\DVBViewer.exe, generated an application error The error occurred on 01/27/2009 @ 16:04:59.078 The exception generated was 80000007 at address 0000000000000000 (wow64cpu!TurboDispatchJumpAddressEnd)
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
(Skipped, total 3000 lines...)
After that I cannot kill the task.
it shows as the following status:
I cannot kill the task of recording service, and also the DVBViewer.exe if I opened it. Thanks
propably a driver issue. the service and viewer can only be as stable as the OS and it's components/drivers...
