No way to record on Astra 19°2 Tr 11567
clb
Since I moved to DVBViewer 4.0, I got a strange phenomenon : I cannot record (either direct or through timer) any channels on Astra 19°2 Transponder 11567. All channels on this transponder are "fre to air". Apparently recording starts, the .mpg file is created, but no content. The recording stops with 4 bytes in the file. The log file indicates an "average data rate" of 0,000 MB/s and a "total size" of 0,0 MB. I noticed something equivalent on transponder 11778, but channels are crypted : this could come from the CAM.
I have no problem to report for recording from other transponders I am using either "free to air" or crypted either on Astra 19°2 or HotBird 13°.
Thanks for your assistance
Can you watch these channels? Have you already tried TS as recording format?
Sorry, i forgot to mention that i watch perfectly those channels, audio and video.
Let me try ts as recording format and come back to you. By the way, i tried ts through TransEdit and the file was not empty, although I was not able to visualize it (by ignorance !).
Best regards
Best regards
Everything works fine with .ts. I checked the results on two 11367 channels with PVAStrumento. So I am switching to the .ts format for recording. Thanks a lot !
