FTA video resolution figure?
Satellite User
I'll consider myself a newbie since I've only purchased DVBViewer about a month ago.
When using Transedit (or maybe even if I have to go to DVBViewer), how do I find out the video resolution of a FTA signal?
In transedit, I've drilled down to the video info in the "Analyze" section, left-hand pane, and I don't see where the video resolution is disclosed.
My main interest is to figure out if the service is SD or HD and if HD, if it's 1080i or 720p.
thanks.
In Transedit you only need to make a right click in the Preview an you getting the DVBSource Options with this informations.
That did the trick. Thank you.
