The One Posted January 30, 2009 Posted January 30, 2009 (edited) Hi all, Hope you can help. I have installed DVBViewer 4.0 and am now trying out the http server with out success. I have read the "read me" file and here are the things I have done. 1.opened ports on windows firewall,router. 2.installed VLC 0.9.8a 3.tested vlc plugin is working from http://comic.sjtu.edu.cn/vlc/play.html 4.tested DVBViewer is working 5.started http server selecting lan ip 6.login to http service 7.tried to start a stream (settings selected. player vlc- preset vlc lan - start stream) Error message: Hangs on "loading video" Any ideas of how to fix this. Do I need to install an older vlc? Thanks for the help Edited January 30, 2009 by The One Quote
The One Posted February 2, 2009 Author Posted February 2, 2009 Hi all, Hope you can help. I have installed DVBViewer 4.0 and am now trying out the http server with out success. I have read the "read me" file and here are the things I have done. 1.opened ports on windows firewall,router. 2.installed VLC 0.9.8a 3.tested vlc plugin is working from http://comic.sjtu.edu.cn/vlc/play.html 4.tested DVBViewer is working 5.started http server selecting lan ip 6.login to http service 7.tried to start a stream (settings selected. player vlc- preset vlc lan - start stream) Error message: Hangs on "loading video" Any ideas of how to fix this. Do I need to install an older vlc? Thanks for the help Fixed by changing the HTTP Server IP to 0.0.0.0 and also installing VLC 0.8.6i and copying the VLC 0.9.8a.exe into the VLC folder. Quote
