French lng DVBViewer 4.0.1
wxyzkmi
Le fichier langue DVBViewer 4.1.0 à votre disposition.
Quelques corrections d'orthographe et ajustements.
French_4.1.0.zip
Edited by wxyzkmi
  • 3 months later...
  • 1 month later...
Please use the attached corrected language file. The french language file installed with the DVBViewer 4.1.1 can cause problems with the DVBViewer.
Fran_ais.zip
I checked the freng Lng 4.1 ave LngEditor Find F3 problem.
The conclusion for the control is no errors found. is this normal?
I compared with English.lng
The language editor only reports missing or obsolete entries.
It will not detect errors like "oui - non" instead of "oui,non" because it does not know about what should be in an entry.
I only corrected the worst problems in the language file which would get the DVBViewer into trouble or would result in wrongly displayed options/entries, I didn't change the words. :)
I only corrected the worst problems in the language file which would get the DVBViewer into trouble or would result in wrongly displayed options/entries, I didn't change the words. :bounce:
File in the French language, English and German spelling of the following lines are:
[OSD]
File comands=Fichier de commande
or
File commands=Datei Befehle
or
File comands=File commands
Is this causing the error?
What is the correct spelling for proper operation?
