lordjohnny Posted January 31, 2009 Posted January 31, 2009 hi. i have windows xp 32 bits clean (formatted 1 day ago) and DVBViewer 4.0 (pay version) and after some seconds (10 seg aprox) recording crash the soft and close. thanks you greetings support.zip Quote
Lars_MQ Posted January 31, 2009 Posted January 31, 2009 Please deinstall the viewer completly including to userdata folder and do a new installation. Make sure you enter the correct Userdata upon installation. Quote
lordjohnny Posted February 1, 2009 Author Posted February 1, 2009 Solved it, uninstall all, and reinstall, all right. thanks you greetings. Quote
