No Log File
Del Boy
I'm having this issue where DVBViewer just closes after about 15 minutes of viewing.. All works fine when I load it again... no log file is being generated..
Does anyone know how to turn logging on?
or even better a solution to my problem!!
cheers
deinstall the DVBViewer completly including the userdata folder and the program folder. Do a clean install and make sure you enter the userdata, that you received upon purchasing the DVBViewer, correctly.
Fixed!
Thanks very much all is workig smoothly without a hitch.. and in time for a massive game in the football today!
Cheers
