Filter graph for Flac
MomoBrut
I am so happy that DVBViewer plays mkv container. I can use just one player for all media, very nice and very fine. Thank you!
A little problem appears now, some containers do not use AC3 audio track but less compressed Flac audio track. It is necessary to install some directshow filter (like madflac) to be able to play mkv with directshow filter graph.
If the graphedit is used, the filter graph is correct ...
The AC3 filter is used after madFlac decoder so the control of all channels is possible. It is the same with Media Player Clasic.
The situation with DVBViewer ...
DVBViewer do not connect AC3 filter after madFlac decoder. The channel control is not possible. It is not possible to play 5.1 channels on 2.0 channel system, because the downmix 5.1 to 2.0 is not possible.
Is there any solution for this? Is there any posibility to force filter chain in DVBViewer?
Thanks a lot for any help.
M.B.
