USpeed Posted February 7, 2009 Posted February 7, 2009 Hi, I just upgraded from 3.x to 4.0.1 (installed the 4.0 and upgraded to 4.0.1) but now I cannot scan channel after upgraded to 4.0, everytime I scan channel, it will prompt "No Hardware available" but I already set and found the hardware under hardware section. During the Scan Channel, the TV driver is not shown under the "Current Device". Mind is using the MIX PCI card and the driver shown 713x BDA DVBT Tuner. Please find attached support.zip. Thanks vm support.zip Quote
USpeed Posted February 7, 2009 Author Posted February 7, 2009 Problem Solved.. Thanks. Hi, I just upgraded from 3.x to 4.0.1 (installed the 4.0 and upgraded to 4.0.1) but now I cannot scan channel after upgraded to 4.0, everytime I scan channel, it will prompt "No Hardware available" but I already set and found the hardware under hardware section. During the Scan Channel, the TV driver is not shown under the "Current Device". Mind is using the MIX PCI card and the driver shown 713x BDA DVBT Tuner. Please find attached support.zip. Thanks vm Quote
CrashingDutchman Posted February 24, 2009 Posted February 24, 2009 Problem Solved.. Thanks. Can you tell us how you solved this problem. I am having the same problem at the moment. Thanks in advance! Quote
CrashingDutchman Posted February 26, 2009 Posted February 26, 2009 I solved this myself by installing the correct drivers (BDA instead of BDA/MCE) for my floppydtv card. Quote
