How do I get a version upgrade?
John Hind
I'm sure I am demonstrating a level of incompetence and stupidity unprecedented in the annals of nerdery, but I really have looked everywhere on this web site and while I find some (ridiculously low-key) references to the availability of a version 4.0, I cannot find any information about how to get a version upgrade from 3.9.4.
If I have to re-purchase, then fine, it is not very expensive, but I would like to know I'm not missing a free or reduced price upgrade path!
This commercial diffidence is quite endearing, but you can take it too far! Most software companies trumpet their version upgrades with a re-designed home page and a battery of upgrade options to encourage existing customers to stick with them!
well you did get your userdata (username/password) for the membersarea when you purchased the viewer, didn't you? Simply log into the Membersarea and there you find the 4.0 and all the other stuff. ;)
Thanks for the missing link!
Douglas Adams is right, but is is also common for product designers to overestimate the amount of mind-space their customers will devote to their idiosyncratic ideas about how to do things! What's wrong with the way practically every other software company works - open download on the product with a time limited trial and sell a licence key?
Hello !
Maybe this solution liomits download traffic and the amount of steeling/cracking the software.(?)
O.K. The Button for the Members Area is really I mean REALLY good hidden.
