Dave1966uk Posted February 10, 2009 Posted February 10, 2009 Hi Probably just me but if I am watching TV and then switch to Radio, what was previously the screen turns black (I have "Hide display is Radio mode" ticked). If DVBViewer is on top the black area remains and obscures the application below. Either way it stays there and the only way to clear it is to close DVBViewer and reopen. Quote
Benarty Posted February 10, 2009 Posted February 10, 2009 (edited) It's obvious that, when DVBViewer is on top that it hides the background application. Black screen? Sure, You have selected "hide display" which turns off Video it's or turned off or turned on and then you get animations during radio playback. or am I missing something as OSD user. Edited February 10, 2009 by Benarty Quote
Griga Posted February 10, 2009 Posted February 10, 2009 what was previously the screen turns black Do you use the EVR video renderer for TV (see Options -> DirectX)? If yes, it's most likely a known EVR problem and will be worked-around in the next DVBViewer Pro release. Quote
