DVBViewer saves data to vista virtualstore
quazzie
I have set DVBViewer to save all config data to application directory.
But i see that channel/scan data some other files dont get written to the installed dir (\Program Files (x86)\DVBViewer) but instead get written to Vistas virtualstore (%UserProfile%\AppData\Local\VirtualStore\Program Files(x86)\DVBViewer).
i guess this is a bug ?
well this is a feature brought to you by MS. So don't use usermode=0 if you don't know what you are doing... You could have just used the suggested options in the setup...
No in Vista a normal started program (even if you use a Admin account) has not the right to save files in Program Files.
If a program tries it vista change the real save directory and map it for this user in the directory were the application has try to save the files.
In Vista you should only use usermode=1 or better usermode=2.
Weak!
Well thanks, reinstalled and choose all users instead.
Thanks.
