ter9999 Posted February 11, 2009 Posted February 11, 2009 I installed Windows Vista and Windows 7 in different partitions. For the most part, things work okay under Windows Vista and Windows 7, but I keep getting the following BSOD (see included image) when watching H.264 TV channels using DVBViewer Pro 4.0. Here is my setup: ASUS ATI 4550 display card. INTEL Q9450 6GB of DDR2 memory MSI P45 mainboard EVR video renderer. Latest Catalyst 9.1 driver. I don't know whether it's DVBViewer Pro 4 that caused this issue. I only see this "video scheduler" BSOD issue when using DVBViewer to watch H.264 channels for some time (maybe 10 mins or less). I'll investigate more. Just post here to see if others also met this problem.. Quote
ter9999 Posted February 15, 2009 Author Posted February 15, 2009 okay, found the root cause. The BSOD was caused by latest ffdshow video decoder tryout. Now I'm using CoreAVC, no such issues. Quote
Vince Posted February 17, 2009 Posted February 17, 2009 Any other solutions? I have Vista 64Bit and Ati 4670 and all HD-channels freeze's after few seconds, codec is PowerDVD 7.###### (can't remember what). With CoreAVC everything work fine, but deinterlacing is much more better with ATI's HW-acceleration. And my processor is little bit too slow to encode 1080i with CoreAVC so some frame drops appear. Not good... Any ideas? Quote
Benjamin D Posted February 17, 2009 Posted February 17, 2009 @Vince, I have 4650 with cat 9.1, using Power DVD 7.3.4407 h264 codec with DVBViewer 4.0, under XP MCE 2005 SP3 - everything works fine on HD channels. Have you tried the hw accel properties in the windows panel to see if it's hw-accel related ? Ben Quote
Vince Posted February 18, 2009 Posted February 18, 2009 @Vince, I have 4650 with cat 9.1, using Power DVD 7.3.4407 h264 codec with DVBViewer 4.0, under XP MCE 2005 SP3 - everything works fine on HD channels.Have you tried the hw accel properties in the windows panel to see if it's hw-accel related ? Ben Hi. No, I haven't, must test that when getting home from work. Quote
