steve Kiwi Posted February 15, 2009 Posted February 15, 2009 (edited) Using DVBViewer 4.0 together with MYXMLTV. To get 7 days of info displayed. I have to.... Open EPG window in "DVBViewer". Open "MYXMLTV" Click IMPORT Wait for MYXMLTV to finish. I know have a 7 day epg If I close DVBViewer I lose almost all my EPG Data, only leaving a few hours displayed. Tried auto import xmltv (Xepg) with same result. Any help please. I Edited February 15, 2009 by steve Kiwi Quote
dvbrewer Posted February 17, 2009 Posted February 17, 2009 Using DVBViewer 4.0 together with MYXMLTV.To get 7 days of info displayed. I have to.... Open EPG window in "DVBViewer". Open "MYXMLTV" Click IMPORT Wait for MYXMLTV to finish. I know have a 7 day epg If I close DVBViewer I lose almost all my EPG Data, only leaving a few hours displayed. Tried auto import xmltv (Xepg) with same result. Any help please. I In Settings>Options>EPG do you have "Persistent EPG data" selected? Quote
steve Kiwi Posted February 18, 2009 Author Posted February 18, 2009 In Settings>Options>EPG do you have "Persistent EPG data" selected? yes it is checked Quote
Lars_MQ Posted February 18, 2009 Posted February 18, 2009 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
steve Kiwi Posted February 19, 2009 Author Posted February 19, 2009 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Ok thanks for the advice Heres the info you requested, and support zip * exact TV-card modell and useed driver version HVR 1100 Driver version 2.122.26109.0 * type and chipset of the mainboard Asus Lithium/intel i945p * graphics card and useed driver version NVIDIA GeForce 8600 GTS Driver version 6.14.11.7824 Quote
Gioxy Posted February 19, 2009 Posted February 19, 2009 ...AFAIU you have to check also "Do Not Receive EPG Data", otherwise your imported EPG data will be overwritten from those belonging from your DVB card... Quote
Lars_MQ Posted February 19, 2009 Posted February 19, 2009 No this won't delete data. If there is really 7 day data from XMLTV it should be saved. (BTW. please check your systemtime/date of the PC this could also cause problems). Please check: Import the xml data, close the DVBViewer and go start -> programs -> DVBViewer program group -> userdata folder. In the following explorer window search for the epg.dat file and check it's size. If it's around 10 byte nothing is saved at all. Quote
steve Kiwi Posted February 20, 2009 Author Posted February 20, 2009 No this won't delete data. If there is really 7 day data from XMLTV it should be saved. (BTW. please check your systemtime/date of the PC this could also cause problems). Please check: Import the xml data, close the DVBViewer and go start -> programs -> DVBViewer program group -> userdata folder. In the following explorer window search for the epg.dat file and check it's size. If it's around 10 byte nothing is saved at all. Maybe thats my problem I dont seem to have a folder called "user data" see attachments of program files folder and config folder. Quote
IRa Posted February 20, 2009 Posted February 20, 2009 Maybe thats my problem I dont seem to have a folder called "user data"see attachments of program files folder and config folder. I don't have either, my epg.dat is in "c:\programdata\cmuv\DVBViewer" folder. Can not see what you have in your tiny attacments. Quote
steve Kiwi Posted February 21, 2009 Author Posted February 21, 2009 I don't have either, my epg.dat is in "c:\programdata\cmuv\DVBViewer" folder. Can not see what you have in your tiny attacments. Sorry guys Are these bigger. can only do 1 at a time due upload constraints see next post Quote
steve Kiwi Posted February 21, 2009 Author Posted February 21, 2009 Sorry guys Are these bigger. can only do 1 at a time due upload constraints see next post heres the confifg files Quote
Lars_MQ Posted February 21, 2009 Posted February 21, 2009 You're right it's called configuration folder in the DVBViewer program group. And it's not the name of the folder but the description of it. Anyway your epg.dat is bigger than 10 bytes so something gets saved. Are you sure the imported data lies in the future? Because on saving all data older than one day is not saved. Quote
steve Kiwi Posted February 22, 2009 Author Posted February 22, 2009 You're right it's called configuration folder in the DVBViewer program group. And it's not the name of the folder but the description of it. Anyway your epg.dat is bigger than 10 bytes so something gets saved. Are you sure the imported data lies in the future? Because on saving all data older than one day is not saved. Yep your right. But the size is constantly changing from 288 k down to 177k. Dont know why, have given up caring. Bigger problems in my life than whats on TV. And of course the the imported epg is in the future, otherwise I wouldn't notice the future dissapear , every time I reopen the epg. I have even tried a total reinstall of DVBViewer. Quote
steve Kiwi Posted July 7, 2009 Author Posted July 7, 2009 Yep your right. But the size is constantly changing from 288 k down to 177k. Dont know why, have given up caring. Bigger problems in my life than whats on TV.And of course the the imported epg is in the future, otherwise I wouldn't notice the future dissapear , every time I reopen the epg. I have even tried a total reinstall of DVBViewer. Right have had time to care. This has been a problem for a long time. I have reinstalled DVBViewer several times, and still had the same result. As soon as I close all of my imported EPG dissapear apart from the 3 hours or so which is broadcast OTA. I have resorted to differnet epg supplier (http://epg.pvr.geek.nz/epg/listings-freeview.xml.gz) and still the same result. Then in a flash of brilliance I deleted epg.dat (in error) from the config folder (this is the file that would suddenly shrink on closing of the programme). The epg.dat file has since rebuilt its self and i now have 7 days of epg on all channels I require. Is this a known bug??? Is it unique to New Zealand???? Has anyone else had this problem Quote
