manually modify trasnponder list for dvb-t
ardua97
hello
i'm from italy
in transedit the ini file for dvb-t in europe is dated 2004
a little uptudated
when i try to scan for dvb-t transedit find less channels than windows media center
so i thought that i can update the ini file manually
with a channel info page like this
http://www.dgtvi.it/dgtvi/copertura.aspx?T...D=5914&CS=1
this the channel list with frequency for my city (rome)
can i update the ini file with the info in that page ?
if so how i have to modify tehe file
if it is not possible there are a place where i can get a uptudated list of dvb-t channels ?
or what can i do ?
Yes. TransEdit is a transponderlist editor and provides everything you need to enter additional frequencies. Read the manual.
As far as I can see, all the frequencies on the dgtvi page are already in the standard terrestrial (EUR) list, except VHF 186 MHz (MUX-B RAI). Enter the frequency in the input area of the TransEdit main window. Set the bandwidth to 7 MHz (most devices don't care about the bandwidth). Click Add and try to scan.
