one license and two machine (not at the same time)
ufuk
hi;
i purchased DVBViewer pro and installed on A machine and run, still watching tv on it
then i built another machine B machine, and i installed DVBViewer pro on this machine with same license...
after i start DVBViewer pro on B machine (not running on b machine) DVBViewer pro shut down byself after a few seconds....
what should i do to use DVBViewer pro on both machine ... at same time..
should i buy another license or what ?
regards....
Most likely you did enter your Userdata wrongly on the second machine. Best thing to do on the second machine: uninstall the DVBViewer completely including deleting the program and userdata forlder and do a clean install and make sure you enter your userdata correctly.
