Unauthorized Posted February 1, 2004 Posted February 1, 2004 I guess it would be nice if there was an option that the viewer could automatically start timeshifting if I press the pause-button. ATM I have to remember to press the timeshift-button before that. Quote
Klausing Posted February 1, 2004 Posted February 1, 2004 Hmmm, for me this is not a good idea. If you want to press on the pause button, why you dont press Timeshift-Record? Many people use pause for changing the graph or record without AV. Steffen Quote
Unauthorized Posted February 1, 2004 Author Posted February 1, 2004 (edited) That's why I wanted to have it as an option, as everybody has another behavior. Personally, I only press the pause button if I walk away from the computer and if I want to resume from exactly this position. If I would only press the timeshift button I would have to search the position (BTW: Sometimes this doesn't work due to the 30min-limitation, but pause works). So I actually have to press two buttons to pause the TV-stream. Also I have to keep in mind wether timeshift is already started or not, so if I would do the same thing again: bye bye! Edited February 1, 2004 by Unauthorized Quote
Technofriend Posted February 1, 2004 Posted February 1, 2004 btw.: what about a symbol in one of the upper corners to display that timeshift is active... such as the red record-circle in the upper left corner?! Quote
Klausing Posted February 1, 2004 Posted February 1, 2004 You dont need this. If you have have activated timeshift you see it in the status bar. Play- Pause- Stop-Buttons are only visible if you activated timeshift. Is that not enough? Quote
Technofriend Posted February 2, 2004 Posted February 2, 2004 If you have have activated timeshift you see it in the status bar. Play- Pause- Stop-Buttons are only visible if you activated timeshift. Is that not enough? Hm, I never saw this... You can't see it if you use a skin, or borderless-mode, or fullscreen. As I do ALWAYS use one of these I never saw it... I thought of something like a blinking green 'TS'-symbol in the upper left or right corner. Quote
Guest hackbart Posted February 3, 2004 Posted February 3, 2004 i thought this is part of the DVBViewer since version 2.0. All you need todo is to enable this option under options->recorder. Christian Quote
Unauthorized Posted February 4, 2004 Author Posted February 4, 2004 What shall be part of the viewer? The function that Technofriend mentioned, or mine? I could find none. Quote
