Subtitles display problem in all version of DVBV
Gary Lam
This problem is discovered for a long period.
Now I confirmed it is the problem of DVBV.
Sample TS:
http://www.mediafire.com/?odjtylzmjmw
I found that the subtitles displayed in DVBV will have much white spot arround the subtitles.
But, I tried VLC Player. The subtitles as normal as the TV.
Here are the result comparison.
A - DVBV:
http://ser1.share.ysk.cc/upload/photo/2009...-GPRUcs2345.jpg
A - VLC:
http://ser1.share.ysk.cc/upload/photo/2009...-GOPXfjmov1.jpg
B- DVBV:
http://ser3.share.ysk.cc/upload/photo/2009...-9ny4EZ5wqD.jpg
B - VLC:
http://ser1.share.ysk.cc/upload/photo/2009...-GJOilprtv1.jpg
Confirmed and fixed :( This was a typical bit juggling related problem, i also added the missing 2bit and 8bit Object Data Blocks - which are not used, but mentioned in the ETSI 300 743 specification.
Christian
Confirmed and fixed ;) This was a typical bit juggling related problem, i also added the missing 2bit and 8bit Object Data Blocks - which are not used, but mentioned in the ETSI 300 743 specification.
Christian
The problem is gone
Thanks~ :(
