Installing latest version
Harryo
At the moment I have DVBViewer Pro ver: 3.6.1..20 installed on my system.
I have just downloaded the latest version 4.0 and would like to know if it can be installed over the existing version, or should I remove
it and have a fresh installation of version 4.0?
If I could just install over the existing version I was hoping it would retain all my existing settings.
Harryo
Backup that folder to a different location. Then install and if you don't like the outcome, delete and copy back from backup.
:blush:
:blush:
Thanks for the suggestion Salvatore will do that.
Harryo
