DVB Viewer and Harmony One
entrecour
Has anyone out ther set up DVBViewer to work with A Harmony One? If so I would appreciate any tips.
Logitech does not list DVBViewer as a remote controlled device (as it's software). Has anyone gone through this process before so that the remote shows channel icons etc? My infrared module is a Soundgraph IMON.
Don't search for DVBViewer, search for your Sat-Card which you use in your HTPC.
