Vobsub in mkv-file!
Björn Rosberg
I have problems making vobsub subtitles in matroska files show in DVBViewer. It does work in WMP 11 and MPC. Text based subs such as srt seams to work though. I had vobsubs working in DVBViewer 3.8.0.0.
I have tried different versions of vsfilter but it doesn’t seam to solve the problem. Right now am I using vsfilter 2.39.
Using ffdshow does work, but look worse and does not work together with other codecs.
Any help would be appreciated
Haali Splitter property page -> Options -> Compatibility -> Autoload VSFilter -> Yes
Thanks for your reply!
I have already set that option to yes. The strange thing is that the textbased subs are working, its only the vobsubs that don't work.
