dvd flickering
krasno
Hi :)
When watching DVD and when objects are moving fast on screen especially if camera is movin up and down I get 3 strange lines aprox. 1/4 down from top of the picture, another line 2/4 down and a 3rd 3/4 down from the top of picture.
.The lines are like they are slower updated then the rest of the picture and not alligned to the rest of the picture to the left.
Hope you understnd this little weird explanation. :)
It happens ONLY when I use my projector a Sanyo z3.
The projected screen is 100" and the vertical lines are 5cm high.
The proplem is not there when watching Tv only during DVD play.
Also not visible on the PC-monitor.
I have tried several codec's but nothing helps
any ideas?
Hi :)
any ideas?
Just realised I did not use the latest version of DVBViewer.
I have now downloaded it but it didn't solve the problem
New Supporttool file added...
Hi :)
any ideas?
Just realised I did not udse the latest version of DVBViewer.
I have now downloaded it but it didn't soleve the problem
+I can add the problem is also there if I use Power DVD..
Hopefully it is not the Sanyo z3, on the other hand when watching Tv from satellite the problem is not there...
I have studied the problem a little more close, it is like the picture is "nervous" during fast scenes, but especially flickering in 3 lines...during camera panning up and down..
sounds weird I know.. but that's the way the problem is..
Edited by krasno
