Valts Posted March 1, 2009 Posted March 1, 2009 I have stripped down myInternet osd plugin to bare minimum which gives me nice access to interfaces like IOSDWindowManager from which I can get currently active window (IOSDWindow). The problem is that it doesn't seem to provide any access to IOSDControl's. So are there maybe some functions I don't know of or the only way is to go and reimplement existing window (kinda stupid) instead of being able to modify it's contents in runtime? Quote
Valts Posted March 1, 2009 Author Posted March 1, 2009 No, this is not possible. Any suggestions how to solve this problem (my target is to dynamically modify controls of the miniEPG)? Quote
Lars_MQ Posted March 1, 2009 Posted March 1, 2009 No suggestions and strongly recommend against it. A lot of stuff is created and destroyed dynamically during runtime and trying to get in between it (maybe even from a different thread) would compromize the whole application and can make it very instable. Quote
Valts Posted March 2, 2009 Author Posted March 2, 2009 No suggestions and strongly recommend against it. A lot of stuff is created and destroyed dynamically during runtime and trying to get in between it (maybe even from a different thread) would compromize the whole application and can make it very instable. Ok... maybe then you could extend the skinengine to be able to read data from variables (just like it can read text variables now)? Things I would be interested in is like, change color of text, position, size, load different image... That should maintain stability? Quote
