skystar hd2 work with dvbviewer?
krishn
I want to buy DVBViewer paid version. will this work with my skystar hd2 card?
any plugin needed for nds v.guard mpeg4 channels? or it will work with paid version?
There are many people in this Forum witch use DVBViewer Pro with the SkyStar HD2.
You need a CI and a CAM witch works with the encryption you Pay TV provider use.
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.info/forum/index.php?act=boardrules
You need a h.264 decoder on your System to be able to watch h.264 encoded channels.
The DVBViewer Pro has no decoder included, but the CD from most DVB-S2 cads has one on it.
