mowax Posted March 6, 2009 Posted March 6, 2009 hi all got my self a twinhan Twinhan and i have it working with DVB dream, but when i try and get it working under devices it just isn't listed....i try and scan but nothing....any ideas what's happening please? or what i can o so the card shows up under "hardware" Thanks Quote
mowax Posted March 6, 2009 Author Posted March 6, 2009 (edited) Hi thanks for the reply, i'm using V4.0.0.0......also ithought i'd post some results of my machine as well.... Computer: Operating System Microsoft Windows XP Professional OS Service Pack Service Pack 3 DirectX 4.09.00.0904 (DirectX 9.0c) Computer Name HOME Motherboard: CPU Type AMD Athlon 64, 2000 MHz (10 x 200) 3200+ Motherboard Name Gigabyte GA-K8NSC-939 (5 PCI, 1 AGP, 4 DDR DIMM, Audio, Gigabit LAN) Motherboard Chipset nVIDIA nForce3 250Gb, AMD Hammer System Memory 2048 MB (PC3200 DDR SDRAM) BIOS Type Award Modular (02/25/05) Display: Video Adapter NVIDIA GeForce 7800 GS (256 MB) Multimedia: Audio Adapter BrookTree Bt878 Video Capture Device - Audio Section Audio Adapter nVIDIA MCP2-S - Audio Codec Interface Edited March 6, 2009 by mowax Quote
Tjod Posted March 6, 2009 Posted March 6, 2009 Do you have BDA driver installed? Try Options > Hardware > Device Scan. If this did not help post you support.zip Quote
mowax Posted March 6, 2009 Author Posted March 6, 2009 Thanks so so much, it was the BDA driver that was missing! thanks very much, and i'm sorry i never noticed it....n00b hu? All working now, just need to work on searching for channels using a correct transponder! ( i think so any way) nice one ! Quote
