How to backup DVBViewer?
calande
Hello,
I had to reinstall Windows, and I didn't know how to backup DVBViewer, so I kept a copy of C:\Programs\DVBViewer but now I don't know what files of this directory need to be restored. I would like to retrieve my list of favorites, and my option settings (especially keyboard shortcuts that I use for my remote control).
Thanks! :blush:
All files witch are changed by the user are stored in the configuration folder > DVBViewer > About > configuration folder.
Backup this folder and restore it after the new installation.
Thanks. That's a lot of files...I thought it was only one or two files... :blush:
favorites > favourites.xml
channellist > channels.dat
keyboard shortcuts > \Remotes\*.remote
option settings > setup.xml, hardware.xml, userdata.xml, network.xml (depends what you have changed)
Best thing is to backup the hole directory.
