error
Theike
Could you try to be more specific? When does this happen LiveTV, playback of recordings or for some video/audio file?
Starting DVBViewer the error occurs uninstalled the ap reinstalling does not help same error.
Gonna try now a clean vista backup to see if it happens agian.
Install the AC3Filter (http://ac3filter.net/) and select it as audio decoder (Options > DirectX > Audio -> MPEG + AC3).
Start the DVBViewer via Start menu > Programs > DVBViewer > Support > DVBViewer Pro (Safe Mode) an than select a no HD channel did work than?
If yes try a normal DVBViewer start if this work try a HD channel.
Restored the backup (love acronis) and no more problems..
Thanks for the help :)
