DVB Viewer 4.0.0 auto closed
jackel
I am using Mygica X8506 with DVBViewer 4.0.0 .
anyone can give help? so much thanks!
Edited by jackel
Here are my suport.zip for reference.
OS: Microsoft Windows XP Professional Service Pack 3
DirectX: 9.0c
Memory: 2002 MB
CPU: Intel® Core2 Quad CPU Q9550 @ 2.83GHz
CPU Speed: 2826 Mhz
CPU Count: 4
Videocard: Intel® Q35 Express Chipset Family
Version: 6.14.10.4943
TV-card model : Mygica X8506 PCI-E Hybrid(DMB-TH+Worldwide Analog)
Thank you for great support! :)
Pleas go in the Registry (regedit) and search for CM&V an compare Username and Password there with them in your authentication email.
Make sure that they in the Registry are the same (case sensitiv). There is a Bug in the DVBViewer 4.0.0 that in the case that they are incorrect the DVBViewer did not show a dialog to enter the correct one.
Thanks you for your suggestion!
I have checked the Username and Password in Regestry. I found that my Username was upperCased.
But I wonder that is it the reason that make the programe close automatically ?
When it was closed, DVBViewer cannot start again. It will show no hardward found . I need to restart my computer to start DVBViewer again.
Anyone face the same problem as me? any solutions?
I am using DVBViewer with plugin netstreaming to broadcast the HDTV video to a web announcement system. However, DVBViewer always close automatically. This make me very trouble!
